Half the sound.
My right side speakers don't work. If I roll down the passenger side window, it'll come on but you have to hit just right. Also going around right hand turns it'll work. It is the whole side that is out and it all comes back on on the right window position or around the turn. Where should I look for a loose connection in the door. Any help would be appreciated.
The door panel comes off very easily, 2 screws i believe(phillips head). after that look down by the speaker, and all around the foam insulation, there are multiple wiring harnesess..should be able to see from there. (I changed out my two fronts with more expensive ones, and it really is an easy job). just becareful to not drop the panel soon as you unscrew the screws because there are Many connections that you wouldnt want to break.
