Hard Start on my 2006 Audi A6
Old Nov 7, 2013 | 04:28 PM
claussenbruce's Avatar
Exclamation Hard Start on my 2006 Audi A6
Are you suppose to hear the fuel pump priming? My 2006 Audi A6 has a hard start when it sits for a long time only….it takes awhile to start my Audi but after it starts it works fine until it sits for like 5 hours. There is no priming noise when I turn the key on before i start my car. It also has smoke coming out the exhaust for awhile and then it does away. It also idles rough for a few minutes then runs fine. Could it be a fuel pump, plugged fuel filter? It takes about 4 or 5 cranks to get it to start. Any help would be great.
Old Nov 11, 2013 | 01:19 PM
crosbo's Avatar
The fuel pump does run momentarily to pressurize the system, before starting. I'm guessing this is controlled by a relay...as it was on our Jag. You can stoop down by the front of the right-side rear wheel and hear the pump run momentarily before starting.
I just changed our fuel filter. Once I drained the filter into a plastic cup and saw how black the drained liquid was, I was amazed it ran as well as it did. My guess is your problem is most likely a combination of issues...fuel filter, MAF and possibly Throttle Body need cleaning etc. All the "usual suspects".
Good luck.
Old Nov 11, 2013 | 06:29 PM
M5S5's Avatar
Tech Certified
Any check engine light? I would have it scanned for any pending codes if the light is not on. Preferably with a VAG-COM , they are much better for reading "pending codes".
rccks96
Aug 29, 2023 08:58 PM
AAndy
B7 Models
Dec 8, 2014 03:25 AM
pisceswheels93
Jun 30, 2014 08:41 AM
Daftbob
Feb 14, 2014 08:31 PM
onelove90
Aug 28, 2012 05:41 AM
