Head R&R on 2.7T
Old Aug 25, 2008 | 12:44 PM
loach1's Avatar
Default Head R&R on 2.7T
Hello, I'm new to the A6 world. I just bought a non-runner with bent valves and have yet to actually see the car. It looks good in pictures and the price was right for my budget.
I have worked on a couple of 2.8 engines before and had no trouble replacing valves after similar water pump failures. I only do this for myself, as a hobby more than anything else, so I don't know all of the ins and outs of the various models.
My question is whether or not I can pull a head on the 2.7T with the engine still in the bay, or does the turbo make it impossible to do without extracting the whole engine? I have searched for threads on gasket replacement but came up with nothing, so please help if you know the answer.
I will do my best to reciprocate on the forum by sharing my experiences working on Audis and VWs over the years.
Cheers,
David
Old Aug 25, 2008 | 01:37 PM
joetm's Avatar
I know the engine has to be pulled for turbo work because of thier placement
Not sure about the head
good luck
Old Aug 26, 2008 | 06:51 AM
loach1's Avatar
Yes, I found a pic showing the engine out for turbo replacement. I was hoping that it was because it easier/cheaper to pull the engine than pull the heads if only the turbos need attention.
I wonder if the heads can come up with turbos still attached??
Old Aug 26, 2008 | 10:38 AM
Coors's Avatar
I would assume you would be able to pull the heads w/ the engine still in the car.
Heres a cut-away of the 2.7T engine
http://images.google.com/imgres?imgu...7SKPB%26sa%3DN
Old Aug 26, 2008 | 07:06 PM
loach1's Avatar
Thank you thank you thank you!
That picture tells all - looks like it is easier to disconnect the exhaust manifold from the turbo model than it is on the non-turbo. That means I can leave the turbos sitting on the exhaust downpipes and remove the heads. Perfect!
Thanks again - this has made an otherwise crappy day a good one. Hopefully I'll have the car by the weekend and will be able to start tearing it apart.
David
Trigger200
B7 Models
Aug 16, 2015 09:35 PM
AudiTurbo
Jan 7, 2014 08:03 AM
mikejones808
B7 Models
Dec 16, 2010 09:42 PM
brian58503
Apr 13, 2009 01:22 AM
ooantipostoo
Sep 14, 2007 04:31 PM
