Headlight Jitter
Hi everyone,
I was hoping someone would know if there is a fix for this;
On my 2005 a6, the drivers side headlight jitters, and when i drive all the signs on the road look like strobe lights. I think this may be due to the mechanism that adjusts the level of the lens, if so can you take apart the headlight assembly and tighten it up?
Also does anyone know if there are any aftermarket headlights for this car that look like the new a4 ones with the LED?
Thanks so much
Thanks so much
Thanks Kevin,
I found the problem. It was the mount for the lens that was loose, all though this headlight was no easy task i tightened up some loose mountings inside and its great again.
Thank you kindly
paulywalnuts446
Feb 3, 2013 02:41 PM
blks4
May 20, 2007 03:04 AM
Influentialstylez
Mar 29, 2007 04:30 AM
