headlight system
Old Mar 12, 2005 | 03:44 PM
rs's Avatar
rs
Default headlight system
im gettin my a6 sometime soon, but 1 thing i wanna kno to look for is the HIDs, how do you kno that you are gettin HIDs, and not just the h7 bulb, i believe the xenon light is an option u have to ask for, correct me if im wrong
but how can i tell them apart?
Old Mar 13, 2005 | 06:03 PM
wh22366's Avatar
Default RE: headlight system
The HID units are low beam only and replace the H1 low beam bulbs in a conventional system. Both systems use an H7 bulb for high beams. If you remove the cover on the back of one of the headlight units, you can see the low and high beam connections. The HID low beam connection is a horseshoe-shaped plastic unit (with a high voltage warning sticker) that's linked to an igniter via a piece of rubber tubing. The conventional H1 low beam just uses a standard blade wire connector.
Old Mar 14, 2005 | 02:23 AM
rs's Avatar
rs
thanks man, the dealer should have the documented too right? or can he be an *** an just say its in there?
Old Mar 15, 2005 | 12:14 AM
wh22366's Avatar
Just make sure that option is on your list when you're shopping. You'll know you picked a good store when one of the things the salesman does is to demo the options you're looking for. I don't know, but I'll bet all the options for particular car are listed in the Audi system software under the vehicle identification number (VIN).
bgrist
Sep 18, 2010 12:45 AM
gabeguimaraes
Sep 1, 2010 07:54 PM
j_dinan
May 19, 2009 12:49 PM
mtngirl
Aug 31, 2008 09:33 PM
