Bulb Warning light comes on now after relaying headlight system....??????????
I have done this mod 100 times & have never had this happen before.
I put 2 30 amp relays- 1 for the High beam & 1 for the Low beam. Each relay is protected by a 30 amp fuse. The power is from the Battery and the relays are grounded to the battery. The Trigger wire is from the headlight switch.
Each headlight is wired straight from the relays. The Bulb Warning Light comes on because the resistance is not high enough. The only thing I can think of is that I cut the wires on the passenger side since they are no longer needed since the that side is being fed from the relay now. Any ideas where I went wrong?
