Heated Engine Signal diagnosis assistance
hello everyone, i've an audi a6 quattro audi wgn. i recently replaced the water pump, thermostat, timing belt, fan belt about 4 months ago. but now after four mnths, my heated engine sign comes on all of a sudden. i drove on the highway for 6 hrs and it is fine but once i'm slow driving or idle the it blinks. kindly advice.
Many thanks.
Many thanks.
Can you be more specific as to what the sign looks like? What does your temperature gauge say when this is happening? Does it read high, low, normal?
If your thermostat is sticking shut, and you continue to drive, you will risk overheating and seriously damaging your engine.
Thank you so much for ur kind response. The temp gauge slowly goes higher. the engine temp signal blinks on the dash board. I just replaced the thermostat. how can i avoid the thermostat from getting stuck? this usually happens when i'm in slow speed or idle.
many thanks
many thanks
If it overheats when your idling it could be your auxillary cooling fans - check the fuse - temp switch - wires - or even the fan motor itself.
Or it might be the low fluid light.. sometines it takes awhile to burp all the air out of the system -- but this is highly unlikely after 4 months
What about the fan clutch? Did you check to see if it was engaging? the way to check the fan clutch is that when the motor is HOT, turn off the car, and try to spin the plastic fan with your hand. If the fan spins, that means your clutch is shot.
aberabee
07-28-2009 09:50 AM
