Help 2.7t Brake Clearance problem (Wheels)
Old Mar 8, 2009 | 10:31 AM
reservoirdog's Avatar
Default Help 2.7t Brake Clearance problem (Wheels)
I acquired some 18 inch wheels off of a passat with the 5x112 bolt pattern. The front wheels don't clear the brakes. Will they fit with spacers? If so which ones will I need and about how much do spacers run? Thanks guys.
Old Mar 14, 2009 | 07:05 PM
Cmoney's Avatar
I have a 2000 2.7. They have a 35mm offset. So I had to get some 5mm spacers. I used a kit from Eibach that cost about $72 for a set. They come with the extra long lug bolts that you will need. Don't try to use spacers with stock bolts. The wheel will come off while you are driving. I got a set for the front and rear to balance the wheels out. Good Luck
Romney-AudiUSAParts
May 14, 2014 03:39 PM
BFlan2001
Sep 8, 2009 01:57 AM
brettofburke
Jul 3, 2008 12:25 PM
