help please !!!
Old Aug 8, 2008 | 08:20 PM
99 audi's Avatar
Default help please !!!
i just got done detailing my car i moved itto the garage so i could wax it and now it wont start. when i turn the key everything lights up but all i hear is a ticking is it my battery or my starter? my car is sticking halfway out of the garage so i cant really leave it where it is please help@!!!!!!
Old Aug 9, 2008 | 01:41 PM
kimi's Avatar
did you wash the engine compartment aswell? is yes then may be you might have soaked the coils, i will suggest you either wait for it to dry up or you take off the spark plug wires at the coil end and dry them up with a hair drier systematically ONE AFTER THE OTHER as you replace them. that may help. try manuvaring the battery terminals aswell. or your battery may have simply died cauz you had too many apliances on while detailing.
Old Aug 9, 2008 | 02:01 PM
oc_audica's Avatar
x2 on battery might have died
Old Aug 9, 2008 | 02:10 PM
kimi's Avatar
you can determine that as such: observe the brightness of the red ignition lights on you dash as you try cranking, if the go deam , then your bat is faulty, if they stay bright then this DX is questionable. you did not mention the question of washing the engine compartment. did you or did you not?
Old Aug 9, 2008 | 02:26 PM
99 audi's Avatar
no i didnt wash the engine compartment when i try and start it all i get is click click click click its not the alternator i dont think because its still drawing amps so im hoping its just the battery a simple 100$ fix
Old Aug 9, 2008 | 02:53 PM
kimi's Avatar
in that case your bat would be 1st as DX. i will suggest you put the car in neutral an push to where you can access the bat. then try jump starting it just to rule out before wild spending
Old Aug 10, 2008 | 04:39 PM
99 audi's Avatar
ijumped it and it started right up so i had to order a battery from the dealership about a 100 bucks not to bad. and it is the original batter from 1999 soi think it had a good life how bout u
Old Aug 10, 2008 | 05:29 PM
cbcustoms's Avatar
If its clicking it sounds like it might be your starter
Old Aug 11, 2008 | 08:05 AM
99 audi's Avatar
thats what i was thinking but if it was my starter would it start by being jumped. i also charged the battery and it started after that but the next day it wouldnt start so i just assumed battery
