Help on replacing A6 transmission/engine break switch
Old Aug 14, 2007 | 10:53 PM
chaoxing's Avatar
Default Help on replacing A6 transmission/engine break switch
My 2001 A6 recently picks up speed very slow after stop.
I use VAG-COM and read the following fault codes. If anyone knows where to get the brake switches and how to replace them, please help. Any advice is highly appreciated.
Address 01: Engine
Controller: 3B0 907 551 BS
Component: 2.8L V6/5V G 0001
Coding: 07252
3 Faults Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-10 - - - Intermittent
16814 - Catalyst System: Bank 2: Efficiency Below Threshold
P0430 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 4B0 927 156 AK
Component: AG5 01V 2.8l5V USA 3132
Coding: 00002
1 Fault Found:
17087 - Brake Switch B Circuit Malfunction
P0703 - 35-00 - -
Old Aug 15, 2007 | 12:08 AM
SSn's Avatar
SSn
Default RE: Help on replacing A6 transmission/engine break switch
Try Blauparts, or pelicanparts search for brake switch. I'm not sure what those exactly are.
Also search the forum for your codes.
tunaoue
Jan 7, 2012 03:37 PM
skipshein
Feb 10, 2011 06:15 PM
SharpHID
May 27, 2008 10:43 PM
iloveaudiii
May 23, 2008 07:13 PM
silveraudi98
Aug 5, 2006 12:55 AM
