Replacing Ignition Switch
Old May 23, 2008 | 10:31 AM
iloveaudiii's Avatar
Default Replacing Ignition Switch
1. Does my 1998 Quatro 2.8L have the immobilization feature that requires the ignition key to be coded by the dealer if the ignition switch is changed?
2. If I cannot get the key out of my ignition, but the ignition still works do I need a new ignition switch?
Old May 23, 2008 | 10:47 AM
NH_USA's Avatar
Default RE: Replacing Ignition Switch
LOL -- I assume you have an automatic and can't get the key out of the ignition.
There is a 75% chance the fix is simple. I actually made $.75 when I performed the fix!
If that is your problem you need to remove the boot around the shifter and dig out the coins and other stuff that slipped thru the gate. When enough stuff gets in there it stops the shift lever from going all the way into park and the switch does not release the key. The stuff is usually found deep at the front of the shift lever. Depending upon what fell into the hole you'll have to use things like a spring nut/screw retriever,sticky stuff on the end of a stick, ora magnetic nut/screw retriever. Sometimes needle nosed plyers work.
Have fun!! [sm=massbounce.gif]
Old May 23, 2008 | 11:05 AM
ahhh this worked..thank you so much for your help..i was about to spend a lottttttt of money. nothing was stuck there but i wiggled the thing into park more....the button wasnt sticking out all of the way. you rock
Old May 23, 2008 | 07:13 PM
a6hcw's Avatar
My1998 A6 2.8L wagondoes not have immobilization. Check www.ross-tech.com for information on immobilization.
devlzluv
Jul 28, 2010 02:07 PM
CoJayT
Jan 26, 2010 04:46 PM
beefski
Aug 18, 2008 03:19 PM
dombombBMX
Dec 13, 2007 07:14 PM
Audi A Fizzle
Aug 11, 2007 12:03 AM
