hissing noise
i have an 98 a6,anytime i start her up i hearthis hissing sound coming from the passenger front,even when i shut it down i can still hear it from inside for about a minute until it goes away,can someone help me?
That is normal. I have the same sound when I first start it on a cold start.. sometimes just with the key in I hear it (with out the car running) and sometimes when I turn it off I hear it for a min or 2 then it goes away. def not a problem
If it truly is a hissing noise I suspect that it would be your a/c , especially if you hear after you shut the car off , as it takes a little bit for your a/c pressure to equalize after shutdown
ORIGINAL: nothing77
