hissing noise
Old Jul 5, 2008 | 04:17 PM
jj2345's Avatar
Default hissing noise
i have an 98 a6,anytime i start her up i hearthis hissing sound coming from the passenger front,even when i shut it down i can still hear it from inside for about a minute until it goes away,can someone help me?
Old Jul 5, 2008 | 04:28 PM
oc_audica's Avatar
Default RE: hissing noise
might be the SAI which is normal
Old Jul 5, 2008 | 05:10 PM
jj2345's Avatar
sai switch? whats that
Old Jul 5, 2008 | 06:26 PM
wammy18's Avatar
That is normal. I have the same sound when I first start it on a cold start.. sometimes just with the key in I hear it (with out the car running) and sometimes when I turn it off I hear it for a min or 2 then it goes away. def not a problem
Old Jul 5, 2008 | 06:27 PM
wammy18's Avatar
you might wana get a clip of the noise so we can make sure it is the same sound though*
Old Jul 5, 2008 | 11:42 PM
nothing77's Avatar
If it truly is a hissing noise I suspect that it would be your a/c , especially if you hear after you shut the car off , as it takes a little bit for your a/c pressure to equalize after shutdown
Old Jul 6, 2008 | 08:08 AM
frankinstyn's Avatar
ORIGINAL: nothing77
I was going to say the same. Mine does the same thing. It'll do exactly the same thing while the car is running if you turn off the a/c. Its normal.
Old Jul 6, 2008 | 09:03 AM
jj2345's Avatar
ok glad to hearthat its all normal,thanks alot guys
Old Jul 6, 2008 | 03:45 PM
NH_USA's Avatar
Don't let these guys fool you!!
Look under the passenger seat for a little green snake.
Old Jul 6, 2008 | 08:24 PM
nothing77's Avatar
always gotta be one smartass lol
