how can i fix it?
Old Apr 24, 2005 | 02:48 PM
S4sweeteeteeRS's Avatar
Default how can i fix it?
i scuffed my front bumper. (ooops) can it be buffed out even tho its plastic? what do i use.
Old Apr 26, 2005 | 12:39 AM
Default RE: how can i fix it?
hello is anybody out there?
should i use a real fine sand paper? will touch up paint work on this? thoughts? comments?
Old Apr 26, 2005 | 12:55 PM
Frost GST's Avatar
It really depends on how bad the scuff is. If it is just on the surface of the clear coat, you can buff it out. If it got through the paint, it will need to be repainted, either with touch-up or sprayed (depends on how big a spot it is). If it damaged the plastic, some body shops can repair small damage on plastic but will probably want to replace the part. Hope this helped some.
Andy
Old Apr 28, 2005 | 09:22 PM
SAFE4NOW's Avatar
There are several companies out there that do "touch up / air brush" paint work at your home / business. They usually charge 100-150 +/- depending on the actual damage. I use them for client cars as well as my own car w. no problems.
here in town I use a company called " Colors on Parade" or " Paint Wizard"
Steve
