how do I know WHICH control arm?
Old Jun 2, 2010 | 03:01 PM
whitey's Avatar
Question how do I know WHICH control arm?
ok, so I've got a creaking/moaning noise coming from the driver front suspension. The upper front control arm was replaced and fixed some of the noise but not all, meaning I've got at least one other control arm creaking. How do I determine WHICH control arm it is that's creaking still?
Or do I have to just start replacing the remaining 3 until I get it right?
Old Jun 7, 2010 | 04:24 PM
Shoebitch's Avatar
Default replace all
I've heard that it is best to replace them all, because if one is bad the others will soon follow. I have another similar thread going...somebody said Febi-Bilstein is best, another suggested an Italian mfg at blauparts.com. The kit is $500+. Let me know how it goes
Old Jun 7, 2010 | 06:21 PM
ninetynineA6Q's Avatar
You could spray each of the remaining UCA's with PB Blaster once a day (one at a time) until the squeaking stops, but depending on how many miles you have on the car, there may be a few that are noisy.
If you decide to change the whole set, I'd recommend febi-Bilstein, but that's the only set I've used. It's not a bad DYI job if you want to save a few bucks, but if you do, search for pinch-bolt threads.
akasjl
B8 Models
May 2, 2014 06:03 AM
JDriver2
Jul 10, 2006 11:16 PM
