How do I turn the check engine light off
Old May 17, 2007 | 11:28 AM
glock40's Avatar
Default How do I turn the check engine light off
I have a check engine light on in 1999 a6 2.8 automatic wagon. I cant turn it off with the diagnostic tool due to the fact that plug in on the car is shot. Is there another way to shut this light off. We have tried disconnecting the battery cables so thats out of the question. Need help a.s.a.p.[:@]
Old May 17, 2007 | 11:39 AM
Jeffla's Avatar
Default RE: How do I turn the check engine light off
unless you know what the problem is and just fix that problem, you will need to repair the obdII plug.
Jeff
Old May 17, 2007 | 11:51 AM
glock40's Avatar
We fixed the problem with the sensor. But we cant get the light to shut off cause of a bad port on the obd. Is there anyway to shut this light off?
Old May 17, 2007 | 11:55 AM
Jeffla's Avatar
Some codes will clear themselves after a certain number of start cycles if the error has been fixed. Other than that i am not sure what you can do. Are you able to fix the obd port? Can you be sure that there is not another problem causing the cel to remain lit?
Old May 17, 2007 | 12:02 PM
RIA6's Avatar
Simple fix...
Turn the key a quarter turn back and pull to the right...
Old May 17, 2007 | 01:19 PM
glock40's Avatar
Ria what do you mean by this?
Old May 17, 2007 | 02:50 PM
RIA6's Avatar
It was a joke…
Sorry to get your hopes up!
By doing that, you would consequently turn your car off; there for no power… which means NO LIGHT!
parlayin
Feb 10, 2010 12:33 PM
Itsheraudi
Jul 23, 2009 02:53 PM
blanthony
Mar 25, 2006 01:18 PM
murphy_boy_2
Mar 13, 2006 09:51 PM
