How easy is it to change the turbo in a 2000 a6 quattro?
Old Dec 23, 2008 | 08:53 PM
RachelsAudi's Avatar
Default How easy is it to change the turbo in a 2000 a6 quattro?
The turbo went out in our 2000 a6 quattro and we are trying to figure out how easy it is to change it. We found the part relatively cheap and were trying to see how to change it out. Can anyone help?
Old Dec 24, 2008 | 12:29 AM
2001A6's Avatar
The turbo? Do you have a 1.8T? If so, should be pretty easy.
If you have a 2.7T, a bit more complicated, with two turbos. I believe the engine may have to come out to do turbos on a 2.7, not sure though. Just 2 cents worth. The more info you can give, the better! Good luck.
Old Dec 24, 2008 | 12:31 AM
trapped's Avatar
You are correct, unfortunately. You have to remove the front bumper and pull the engine, I wish I had the tools to do such a job.
AudiGirl92
B7 Models
Dec 11, 2013 10:53 AM
jaesae84
Aug 12, 2012 12:56 AM
jaesae84
Jun 7, 2012 03:10 PM
wtfs
Apr 30, 2012 01:50 PM
A-Tone15
Oct 16, 2010 10:52 PM
