how easy is it to change brake pads
Old Apr 28, 2012 | 04:23 AM
wtfs's Avatar
Default how easy is it to change brake pads
hi all i sent my car in for a servicing recently and the mechanic told me that my brakepads were wearing thin. ive managed to source for my own pads relatively cheap but he was gonna charge 98aud(australian) to put em in.
i was just thinking of being cheap and doing it myself. im pretty i can get to the part where the calipers comes off but i see that you have to use a winch to push the brake fluid back or something? whats that about?
Old Apr 28, 2012 | 08:11 AM
jonbonesjones's Avatar
Moderator
easy, if you own a car you should be able to do this.
http://forums.audiworld.com/showthread.php?t=2797647
you need a "winch" in america its called a c clamp. it pushes the piston back in because the pressure in the lines push it out
Old Apr 28, 2012 | 04:20 PM
turbo kraut's Avatar
Tech Guru
honestly, if you have to ask about changing brake pads you shouldn't probably do them
Old Apr 28, 2012 | 05:09 PM
livinglegend2100's Avatar
and also, you cant just use a c-clamp (for the rears anyway). the calipers are not a "push in" type, but more of a "screw in" type. you have to turn the piston as you push it. much like tightening up a bolt. they make a special tool for it, or you can put pressure on it with a c-clamp, and turn the pistona couple times then tighten up the c-clamp again. and repeat. like a hundred times.
but that being said, its relatively easy if you have any kind of mechanical aptitute. if you can get the caliper off, then youre fine. and make sure to lube the slide pins on the caliper bridge.
Old Apr 28, 2012 | 07:41 PM
wtfs's Avatar
i understand but we've gotta start somewhere right? always a first to everything.
Old Apr 28, 2012 | 07:42 PM
wtfs's Avatar
damn that sounds....
but alright thanks for the advice mates!
Old Apr 29, 2012 | 04:18 PM
FishEye's Avatar
its easy man... just follow the link jonbonesjones provided and you'll learn... and livinglegend is right about the rear brakes... you need a special tool to kinda screw the piston back in and also you have to align the little notches on the piston so the new brake pads can sit on them right... but its not too hard bro. the more you work on your own car the more you love it! good luck
Old Apr 30, 2012 | 01:50 PM
savantv's Avatar
I was told last week I need to do my rotors so I'll be performing that writeup soon too!
If you guys haven't figured it out yet you can search other forums too using
vagsearch.com (sticky from general tech section)
jinsojoo
Sep 16, 2021 04:49 PM
airmancjh
B7 Models
Oct 5, 2009 11:44 PM
RachelsAudi
Dec 24, 2008 12:31 AM
nc 2.7t
Jan 6, 2006 02:54 AM
black b5
Jun 1, 2005 09:36 PM
