how much are these
Old May 7, 2008 | 03:03 AM
WeezyTT's Avatar
Default how much are these
http://www.youtube.com/watch?v=Pqt62...eature=related
Im assuming they are/sound the same on the 2.7t a6
This guy sounds like hes got a wastegate from a ****** supra
http://www.youtube.com/watch?v=v59A1zdMv80
Old May 7, 2008 | 02:28 PM
Joeski's Avatar
Default RE: how much are these
They are a Forge Hybrid combo recirculation/blow off valve. Price should in the area of $130. thru $160. each.
OOOO
[IMG]local://upfiles/13659/AE40DAC7528A47FEB4E348D4033289A0.jpg[/IMG]
Old May 7, 2008 | 06:09 PM
joetm's Avatar
yo i have these things ... tell me how the hell i get them to sound like the utube video bc all i get is a loud whistle throughout like 1700-2500 rpms n then no blow off sound ... also my top end acceleration SUCKKKSSSS because i guess the boost is not retained ... i am going to tighten up the spring so it doesnt release as early and see if that helps but i really want the sound from the you tube video ... how???
Old May 8, 2008 | 08:10 AM
Joeski's Avatar
ORIGINAL: joetm
Hey Joe,
Did they come with different springs? It sounds like the spring in the valve is not strong enough. APR was having the same problem with their R1 valve on the 2.7T engines. I saw some people take the R1 apart and replacing the spring with one of the Forge springs. The Forge springs are color coded for different boostrating.
My bro-in-law had the problem on his S4 with the R1. It was a constant whistling noise.
OOOO
Old May 8, 2008 | 09:48 AM
joetm's Avatar
hmm i did hear about a spring problem with the forge hybrid splitters ... how would i go about replacing the spring? or which spring should i get to replace it with ... im running k03s with the giac chip im guessing my boost is like 15psi??? dont have the gauge in yet ??
Old May 8, 2008 | 11:02 AM
Joeski's Avatar
I know that the springs are available on Forge's website. I believe it is a set of 3 or maybe 4. I think there is a technical section to be able to download instructions. If you believe you are pushing 15lbs of boost, I am certain that their springs will cover a range of boost, for example (15-20lbs of boost) and so on. I would check their site. I would think that you could take the DV apart like their 007.
OOOO
Old May 8, 2008 | 11:11 AM
joetm's Avatar
i talked to a guy at forge he said they didnt have spring kits lol... im gonna search the website now ... it is a fully servicable valve!
Old May 8, 2008 | 11:39 AM
Joeski's Avatar
Hey Joe,
Here is the link.....
http://www.forgemotorsport.com/conte...roduct=FMDVTUN
Old May 8, 2008 | 12:19 PM
joetm's Avatar
the link was not working but im pretty sure i found them they are 15 bucks so i bought 2 one for each splitter ... ill let u kno what happens ... is thier anything else available to make that whoosh sound besides the splitters
Old May 8, 2008 | 02:25 PM
Joeski's Avatar
I do not think there is anything else available. If you want theBOV, you purchased the right set! Lemme know how the springs work Joe!
Good Luck!
OOOO
