How to reset my ABS???
Old Jan 29, 2009 | 11:32 PM
millenia's Avatar
Smile How to reset my ABS???
Ok guys just got my module back for one of the A6 i have. Had a code P1606 these awesome people from module master took care of it. I put it in go into the snow slam the brake, bam my abs works and eveything is good. But when i scan with my vag scanner, it still shows the P1606 code, will disconnecting the battery for the night work for me???
Old Jan 30, 2009 | 12:12 AM
nm3210's Avatar
Well i'll ask the obvious: did you clear the code??
Old Jan 30, 2009 | 12:26 AM
millenia's Avatar
yea i cleared the code and still is on when i scan it again, i think the bettery disconnection should do it but i m not sure
Old Jan 30, 2009 | 12:44 AM
twinturbomew's Avatar
Well the code is classified or identified as
Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction.
So check the connection or maybe they fixed one thing and disturbed another in the electrical connection. If you cleared the code more then once then disconnecting the Batt is not going to do anything. For the most part you are not going to clear any codes by disconnecting the Batt.
Try clearing the codes in the ECU then back to the ABS. There is a chance that there are multiple codes stored around the modules that are creating the code
Old Jan 30, 2009 | 09:07 AM
millenia's Avatar
k i ll try
Old Jan 31, 2009 | 10:48 PM
millenia's Avatar
no news, same results
Old Jan 31, 2009 | 11:31 PM
chefro's Avatar
If your Brake warning light is not on and your ABS works, I don't see why you need to worry about a code in the ECU's memory.
Did you try to clear the codes in the ECU/ECM as it was suggested? From the reply it isn't clear if you tried that or not.
peter121
Mar 13, 2012 01:33 PM
JaceTun
Sep 12, 2009 01:28 PM
bihoang
Feb 24, 2007 10:54 PM
dtownhotcorner
Jan 31, 2006 06:39 PM
auto3251
Dec 5, 2005 06:14 AM
