How to tell if car needs inner and outer tie rods
Old Jun 30, 2009 | 10:35 PM
Cmoney's Avatar
Default How to tell if car needs inner and outer tie rods
I have a 2000 2.7. I was wondering how to tell if it needs inner tie rods. I know it needs the outers. Also, what is a good brand and how hard are they to put on? Thanks
Old Jun 30, 2009 | 11:41 PM
auditech79's Avatar
The inners take a long damn time to wear out on these cars, (200,000+) so i doubt you need inners unless you are in a climate thats really cold any they put salt on the roads.
The outers can be a pain to change if they are rusted/frozen on the steering rack. I would soak the outer tie rod ends with PB blaster the day before working on it, then try to break them loose the next day. Just make sure to COUNT how many turns it takes to remove the tie rod end. It usually takes between 21 and 23 turns to remove it. Put them back on with the same number of turns, put it all back together and have the car aligned.
Old Jul 2, 2009 | 01:38 AM
Cmoney's Avatar
Thanks a lot!!! I'm gonna try to do it myself and save a little money. Any brand of tie rod in particular that you recommend? And what is PB blaster and where do I buy it?
Old Jul 2, 2009 | 01:47 AM
Midniteoyl's Avatar
Old Jul 2, 2009 | 12:27 PM
formulagigi's Avatar
I had done my outters last year, and my inner (driver side went bad) so I just had it replaced last weel Clunking sound over bumps and man holes finally gone) at only 86k miles! Was not expensive though.
Old Jul 3, 2009 | 07:04 AM
Cmoney's Avatar
Hey FormulaGiGi, what brand of tie rods did you use? Are they pretty much all the same? Thanks a lot guys. I appreciate the help.
ECS Tuning
Oct 31, 2014 03:44 PM
pete7
Dec 22, 2008 04:40 PM
hcaudikeed
Nov 17, 2008 03:31 PM
k5gixxer
Jan 23, 2008 11:03 AM
afruss2007
Oct 7, 2005 06:55 PM
