How to use Triptonic
Old May 16, 2007 | 01:07 PM
myaudia6's Avatar
Default How to use Triptonic
Can anyone guide me on this. I have a triptonic option, and dont know when and how to use it.
I tried using it once, but i made a noise, so can anyone guide me the right way. Thanks
Old May 16, 2007 | 03:59 PM
jgurland's Avatar
Default RE: How to use Triptonic
Do you know how to drive a manual transmission? Tiptronic is just like a stick, but there's no clutch. You just shift up or down like you would in a car with manual transmission.
Old May 16, 2007 | 04:22 PM
kloubek's Avatar
All the Tiptronic does is shift for you. It should be virtually noise-free. If yours is making a noise, I'd venture to guess it is defective in some way.
Keep in mind that the car will automatically shift your 1-2 for you. From 2 up, you have full control.
Old May 16, 2007 | 04:47 PM
TI3VOM's Avatar
I use mine during heavy snowstorms, especiallyin stop&go traffic.
Old May 18, 2007 | 01:26 PM
Frails's Avatar
I know I will catch some replies for this but I am absolutely convinced that my 2000 A6 4.2L lost reverse because of my use of Tiptronic. Maybe coincidence but the car drove fine until one day I decided to use it all day. I can drive a stick, have owned Porsche's so I'm not new to performance and did not "beat" on my A6. I don't really have anything to back this statement up with other than intuition. But I am convinced the reverse issue in the 4.2'sis linked to the Tiptronic design. So use it sparingly friends.
A discussion on another Audi forum site suggested that when he shut off his ESC, he got reverse back. I have no idea what the ESC is. Any suggestions?????
Old May 18, 2007 | 01:43 PM
EnviedA6's Avatar
If your so convinced that your Tiptronic is the reason why you lost your reverse, why don't you take to a shop to have them look at it.
Tiptronic shifts up and down gears and has nothing to do with your reverse gear, unless you slammed it into reverse which would be dumb if you did but I would look into it.
Old May 18, 2007 | 09:23 PM
SSn's Avatar
SSn
Many will disagree but I don't see any use from triptronic. It's just the sales thing to make people who are incapable to drive normal car (5 speed=) feel better.
In my opinion auto is more effective in snow/bad weather. I drive 5 speed all the time, and snow, well it's easy to go with auto, you can just limit it to no go more then 3 or 4th and it will be better then manual - mainly because off easy ans smooth starting in 1st. =)
Now, myaudia6, you move the level into triptronic position and just tip it to + or - when you want it to shift to the next gear or back. I tried it once - did not like it at all. You'll wear your clutches, like some people like to 'shift' auto from 1 to 2 to 3 and to D.... I think triptronic is not that bad but il worse then just letting it thift by itself in D. Remember, the car is much more capable then the driver! %) If yours making sound - forget about it, you'l not loos much anyway.
Frails - your rear problem is probably hydro related. Plugged valves or something like that. Depends what it does. Anyway it can be fixed by your own means. You'll have to get transmission jack and a few days to fix it though. I've repaired automatic transmission once, it took me 6 days to do. I repolished all the hydro valves and replaced both differential bearings - fixed the problem of not shifting at all %)
Old May 19, 2007 | 12:47 PM
Frails's Avatar
The reason I won't take it into the dealer is because of the outrageous rates. I've got a $2500 quote from an indie and that's the route I'm going. But first things first...I'm having a complete timing belt, water pump, thermostat, , dampener, belts and rollers job done tomorrow for $850.
Thanks for the thoughts on the hydro angle. Only input I can give is that since I live in AZ and it's 100 degrees right now, it grips just a little more in reverse, meaning the expanision of materials due to heat is affecting the seal or fit for greater compression. Does that make sense? I've heard the seals can get chewed up pretty easily and the tranny kits have completely different seals now. Either way, at 68k miles I'm just gonna have the tranny rebuilt and be done with it. Love my 4.2L!!
Old May 21, 2007 | 01:33 PM
votblindub's Avatar
did audi put anything about using that in the manual? i never actually looked
Old May 21, 2007 | 10:36 PM
myaudia6's Avatar
they jut say tht move up and down to change gears. it doesn't help a lot!
