I just found a leak
Old Nov 18, 2004 | 06:38 PM
HoosUrDaddi's Avatar
Default I just found a leak
I am the new owner of a 2000 A6 2.7T , 6 speed with 48,000 miles on the clock.
It appears that i need to replace the camhsaft and crank seals due to leaks.
Does it make sense to replace the timing belt while I am there?
Additionally, what other maintenance items should I take care of, i.e. water pump, tensioner, serpentine etc?
I know it may be early due to mileage but does it make sense to leverage the labor cost at this time?
Thanks in advance
Al
Old Nov 18, 2004 | 07:55 PM
Jestnomen's Avatar
6th Gear
Default RE: I just found a leak
Yeah you might as well replace the timing belt and all the extras as you said.
Old Nov 19, 2004 | 03:12 PM
99a4audi's Avatar
while ur there i think u should. Better now then to do it later and do it all over again. Personally i would if i were u
Old Nov 19, 2004 | 04:45 PM
Jestnomen's Avatar
6th Gear
may want to replace the snub mount also.
Old Nov 20, 2004 | 01:21 AM
Thanks all
The guy I bought from had already replaced the snub mount.
I just picked it up today so I will give it a good washing and post some pics
Al
Old Feb 9, 2005 | 10:58 AM
jgfes3's Avatar
I have the same issue --- is this a common problem with the 2000 2.7T?
How much did it cot to fix - head gasket and sepentine?
Old Feb 9, 2005 | 01:05 PM
clconversion's Avatar
yes it is a common problem with the 30V 2.8's and 2.7's also I would sudjest replace the water pump and thermostat while your in there to its just all preventive maintance
Old Feb 10, 2005 | 11:44 AM
jgfes3's Avatar
What was the cost - did you have a dealer do it?
spaniel1287
Jun 28, 2014 05:34 PM
IaHum
May 20, 2012 09:40 PM
mochsl99
Dec 5, 2010 02:58 PM
BraMas
Oct 19, 2007 04:38 PM
wienerwate
Mar 7, 2005 11:43 AM
