I know some one has done an tip -Man. Conversion
Old Nov 13, 2006 | 09:59 PM
Mac_17's Avatar
Default I know some one has done an tip -Man. Conversion
I know some one has done an tip -Man. Conversion. I have seen it before. If this was you let me know I got a ton of time to work on my car but I want to see if its feasable. I have to replace the tip on it here soon I have too much Hp's for it.
Jason
Old Nov 14, 2006 | 12:16 PM
slee22's Avatar
Default RE: I know some one has done an tip -Man. Conversion
PM Baskin 4.2l, he's got a 6-speed in his 4.2
Old Nov 15, 2006 | 08:27 AM
Baskin 4.2l's Avatar
Thanks slee22
Mac I have a 6 speed in my 4.2 A6 I also changed my motor to a S8 ( well I actually didn't do much the guys at VAST did but...)
There is a ton of stuff you can do to the tip. What motor do you have?
I just saw a tip S4 that made 475 WHP
I went for a ride in a tip pasatt that made 337WHP
Both rode well and were very strong
The conversion is very in depth you need to change everything from parts of the harness to the peddle assembly to adding a master cylinder.
I payed a little over 8000 to have mine done. But I had all new parts put in
Old Nov 15, 2006 | 02:39 PM
Mac_17's Avatar
Hey thanks for the tip (no pun intended). I can get a manuel tranny used with few miles on it for 2k and I know I would need another 1k in parts. By any chance do you know how many hours it took? Thanks for the heads up I'm thinking about doing this over the summer while I'm in Egypt so I get back to a manuel. The problem is I know I will blow this tranny. Hey how much for the s8 motor, I have the 2.7t now with all the features APR stage2 all that type of stuff. I plan keeping the engine of my 2.7t to transplant into my Westfield xtr. Anys thanks for the help and where is Vast located?
Jason
Old Nov 15, 2006 | 06:25 PM
Boston Driver's Avatar
I've heard that the B6 S4 manual tranny is virtual plug-n-play for the C5 A6 4.2. True?
Old Nov 16, 2006 | 06:13 AM
Mac,
VAST is located in Detroit Mi. If I were you I would keep the 2.7T There are a lot of mods out there for that. The guys at vast have 4 running GT turbo kits on the 2.7T ALL of them make over 600WHP on low boost and pump gas. You might want to E mail them
Hey Boston,
They had a B6 trans there and It looked quite a bit different. I believe that the timing belt chain being in the back of the motor might have made the tranny different. Or at least appear different
audi99
Apr 3, 2012 12:50 AM
caddy2audi
Sep 12, 2007 06:30 PM
BearTrap
Dec 30, 2006 02:07 AM
akielb
Oct 6, 2006 11:41 AM
