I need brakes on my 00 A6 2.7t Quattro
Old Oct 2, 2011 | 09:08 PM
xcrider's Avatar
Default I need brakes on my 00 A6 2.7t Quattro
Is this something i can do my self? Keep in mind ive built a jeep and modded a mustang. So brakes in general arent something new to me. Just wondering if theres anything special that needs to be done. Or any special tools.
Also what parts are reccomended for a daily driver?? I need both rotors and pads. Also what tools will i need?
Old Oct 3, 2011 | 06:16 PM
bob martin's Avatar
The only special tool will be a brake caliper set to help get the rear pucks back into the caliper. I use Zimmerman rotors and Hawk HPS pads. I get mine from ECS Tuning.
Bob
Old Oct 4, 2011 | 01:24 AM
evelluser's Avatar
What is the special too exactly? and where can you get it from? is it ABSOLUTELY necessary?
Old Oct 4, 2011 | 09:22 AM
hxgaser's Avatar
A couple of things...
1. The rear brake pistons will only retract if you spin and push. It won't work if you just push. You can get a full blown kit that has the piston compressor and attachments, or get something called a brake piston cube. You can get these pretty much anywhere.
2. Check your rear rotor size and depth. More than one size were used in your model.
Old Oct 4, 2011 | 10:35 PM
CRuby's Avatar
I have the same car '00 A6 2.7T Quattro.
Seems like there can be different styles of front brakes. Mine had 4 pads/wheel, while some others could have 2 pads/wheel. The pads are different sizes. So be sure to get correct replacements. Also I think they have different rotors. I had 321mm dia. w/ 30mm thickness. Got replacement from Adv. Auto, but the hat size was too big, so they didn't fit. I returned them & ordered online. Some of the online audi parts sites point these differences out, & they also sell kits of rotor + pads. Check your brake hose while your down there. Both L & R sides of mine were cracked bad due to age & abuse.
I haven't got to the back yet. But, as I suspected, yet another special tool. Here's some links I found useful, also searching forum with good keywords helps too.
http://www.audiworld.com/tech/wheel24.shtml
Audi Brake Rotor Options - How To Measure Audi Brake Rotor Size
Old Oct 21, 2011 | 04:52 PM
xcrider's Avatar
THanks for the help. Turns out the rotors DONT need to be replaced. So just the pads.
Soupie
Apr 20, 2008 10:43 PM
AudimaniaA4
Mar 23, 2008 08:14 PM
jrcunning1
Jul 20, 2007 08:02 AM
Chandlerman47
Jan 19, 2007 08:39 PM
fatdog1012
Nov 20, 2003 04:02 PM
