idle rpms
Old Nov 16, 2008 | 04:56 PM
nrf1211's Avatar
Member
Default idle rpms
I was wondering what the normal idle speed should be for a 2000 a6 2.7t 6spd when its warmed up. Sometimes it will idle at a little under 1000 sometimes it will be like 600 others like 800 and on occasion it will sit and bounce back and forth from like 600-800 like a rough idle. Anyone know what the cause could be? also it misfires on occasstion too when under a load. im wondering if the problem is linked
Old Nov 17, 2008 | 06:12 PM
nrf1211's Avatar
Member
noone knows?
Old Nov 17, 2008 | 06:16 PM
oc_audica's Avatar
Idle should be around 900
New spark plugs might help a bit... otherwise test for vac leaks.
Old Nov 17, 2008 | 06:44 PM
ppgoal's Avatar
Mine is steady at 800-850 per the tach. And I have 119k on the car. Plugs or air filter is the cheapest first fix. Vacuum leak makes sense, too, but tougher to find.
Old Nov 18, 2008 | 12:26 AM
nrf1211's Avatar
Member
can a vac leak cause mis fire on occassion too? and also whats the best way to test for vac leaks.. its not the air filter i have a pretty new one.
Kite09
Sep 12, 2014 09:27 PM
muckdawg24
Dec 24, 2010 03:46 PM
inetforce
Mar 9, 2009 03:26 PM
black19
Sep 13, 2007 04:20 PM
A4speed
Sep 4, 2006 04:15 PM
