Two Quickies. Idle RPMs & accelleration Q's
Old Sep 12, 2007 | 12:21 PM
black19's Avatar
Default Two Quickies. Idle RPMs & accelleration Q's
First Question:
What is the normal idle RPM range on my 03 Audi A4 1.8T? It seems to be idling a little rough and close to 1K. Is this normal?
Second Question:
When I get on the gas or if I'm climbing a hill, there seems to be a metallic-type smell that comes through the vents. Once again, is this normal?
I just bought my A4 this weekend and I'm taking it back to the dealer to have them look at some misc. things and I just wanted to get an idea of whether or not I should be concerned about the above mentioned things.
Old Sep 12, 2007 | 12:25 PM
techbod's Avatar
Default RE: Two Quickies. Idle RPMs & acceleration Q's
idle speed should be around 800 and its probably the catalyst that's bad so get it checked for fault codes
Old Sep 12, 2007 | 02:01 PM
2k S4's Avatar
I would also clean out the TB, check for boost leaks, & make sure all the filters are clean.
Old Sep 12, 2007 | 09:38 PM
black19's Avatar
Not sure if this helps but I did notice that the idling seems to be at 800 which appears to be the correct area, but if I have the AC on, the idling is drasticly smoother. When off, it seems a lot rougher. Does this help with any DX?
Old Sep 13, 2007 | 04:20 PM
black19's Avatar
Well, the dealer didn't find any fault codes. Maybe it's just me. My service tech did mention that he thought the fuel pump was a little louder than normal but it was still functioning correctly and because of that, he couldn't replace it as it's covered under warranty and if I want it to be covered, it has to be not functioning.
Kite09
Sep 12, 2014 09:27 PM
muckdawg24
Dec 24, 2010 03:46 PM
inetforce
Mar 9, 2009 03:26 PM
nrf1211
Nov 18, 2008 12:26 AM
A4speed
Sep 4, 2006 04:15 PM
