immobiliser problems
Old Jan 7, 2006 | 12:04 PM
yamman's Avatar
Default immobiliser problems
Hi all, i have recently bought a 1997 A6 1.8T and have been having intermittent problems with it regarding the factory immobiliser. After a bit of investigation i have figured out what the problem is. Take of the cowling around the steering column and you will see two wires going into the ignition barrel. The wires are twisted around each other and then bent at 90 degrees into a black connector. Ihad a broken wire at the bend and this is what was causing the problem. After a bit of soldering and reinsulating the wire problem solved. Hope this will be of help to anyone out there
Old Jan 9, 2006 | 12:18 PM
misko's Avatar
Default RE: immobiliser problems
if your talking about a tranponder type imobiliser Audi did not add
this to there cars untill 2001. These may just be ignition wires?
Old Jan 15, 2006 | 08:27 PM
yamman's Avatar
I should have said that i live in Scotland and it is a european model. As far as i know these immobilisers are standard on cars after 1997.
NeilDoody
Jul 26, 2013 08:49 AM
andi.u.k
B7 Models
Apr 29, 2010 05:58 PM
knapsal
Nov 18, 2006 10:44 PM
jay2jay99
Mar 8, 2006 01:44 AM
jay2jay99
Mar 5, 2006 11:10 AM
