Interior door trim removal?
I have an earlier post about removing the passenger door panel on a 1995 A6, I am sure I have to remove the interior door trim. But to no avail. I really don't wanna screw up the trim, can anyone help guide me in the right direction?
Door trims[/align]Removing and installing front door trim (4- and 5-cylinder 07.93 ä, 6-cylinder, S2)[/align]
Note:
â—†Manual window lifters and manual mirror controlâ—†Removing and installing impact absorber for front door trimClamping washer
Insulation
â—†Attached to trim by retaining ring -item[/ul][/ul]
â—†Ensure that only undamaged dampers are fitted [/ul][/ul]
Clamping washer
Bolt - 1.2 Nm
â—†Qty. 2 [/ul]
Trim cover
â—†Attached to trim by clamping washer Door handle holder [/ul]
Door handle
â—†Removing and installing finger plate top section â—†Removing and installing finger plate bottom section Hexagon socket screw - 2.5 Nm [/ul][/ul]
Switch cover
â—†For electric window lifters, electric seat adjuster and safety switch for electric window lifters. [/ul]
Trim
â—†Number and position of retaining hooks => Fig.20[/size]21
â—†Remove trim upward
â—†Before fitting, fit door handle seals [/ul]
Inside door control
â—†Undo screw for inside door control [/ul][/ul]
â—†Press in direction of travel
â—†Remove from door trim
â—†Detach Bowden cable Door locking mechanism locator [/ul]
Lock ****
â—†Not necessary to remove in order to remove trim
â—†To remove, rotate approx. 1/2 turn (180o) anticlockwise and detach
â—†To fit, slot into place and rotate approx. 1/2 turn (180o) clockwise
â—†Installation positionAdjusting clip [/ul]
â—†Adjusting[/ul][/ul]
→ Fig.1Number and position of retaining hooks, front door
→ Fig.2 Detaching Bowden cable
‒Lever off clip -2-.
‒Detach Bowden cable. [/ul]
1 -Seal [/ul]
→ Fig.3Lock **** fitting location
â—†When fitted, the locating cam must point towards the door window.
â—†Dimension a = 14 mm, button locked. [/ul]
→ Fig.4Front door trim height adjustment
‒Adjust height parallel to window slot strip on outside -1-.
‒Set trim flush to dash panel.
‒Correct height as necessary using adjusting screw -2-. [/ul]
3 -Door subframe [/ul]
‒→ Position flat screwdriver in hole on underside of finger plate.
‒Push back lugs at both holes -arrow- and lever off cover. [/ul]
Note:
Lever off cover from front towards rear.
‒→ Unscrew 3 cross-head screws -2- from finger plate bottom section -1- (2.5 Nm). [/ul]
3 -Finger plate top section [/ul]
Note:
â—†Old armrests can still be fitted to the new door trims.
â—†New finger plates cannot be fitted to the old door trims. [/ul]
Removing and installing front door trim impact absorber
‒Remove front door trim ‒→ Open 2 clips -4- using Seeger circlip pliers -6- and lift off.
‒Detach impact absorber -2- from door trim -1-.
‒Clean adhesive residues from bonding surface on door trim.
‒Detach adhesive protection strip and affix impact absorber.
‒Slot clips -4- onto locating pin -3- using 10 mm socket wrench. [/ul]
‒→ Press on the two retaining lugs of the clip -2- with a screwdriver -1- to bond the impact absorber -3-. [/ul]
[IMG]local://upfiles/12092/7AE1B7D7AAF44AB4B6C0A792B6F78308.jpg[/IMG]
[IMG]local://upfiles/12092/4A179F9674764E78BE7C26F5C372A2D4.jpg[/IMG]
[IMG]local://upfiles/12092/430DAEAE0BC14755A9504EA325E1A5F9.jpg[/IMG]
[IMG]local://upfiles/12092/6DA93A614FD24DB68115E9E7B90D8AB6.jpg[/IMG]
[IMG]local://upfiles/12092/52F2758377034B2B802890F8DBDFEA63.jpg[/IMG]
nismonewf
Nov 27, 2008 08:43 PM
