Interior door trim removal?
Old Dec 2, 2007 | 10:02 AM
Stargazer's Avatar
Default Interior door trim removal?
I have an earlier post about removing the passenger door panel on a 1995 A6, I am sure I have to remove the interior door trim. But to no avail. I really don't wanna screw up the trim, can anyone help guide me in the right direction?
Old Dec 2, 2007 | 10:19 AM
techbod's Avatar
Default RE: Interior door trim removal?
Door trims[/align]Removing and installing front door trim (4- and 5-cylinder 07.93 รค, 6-cylinder, S2)[/align]
Note:
โ—†Manual window lifters and manual mirror controlโ—†Removing and installing impact absorber for front door trimClamping washer
Insulation
โ—†Attached to trim by retaining ring -item[/ul][/ul]
โ—†Ensure that only undamaged dampers are fitted [/ul][/ul]
Clamping washer
Bolt - 1.2 Nm
โ—†Qty. 2 [/ul]
Trim cover
โ—†Attached to trim by clamping washer Door handle holder [/ul]
Door handle
โ—†Removing and installing finger plate top section โ—†Removing and installing finger plate bottom section Hexagon socket screw - 2.5 Nm [/ul][/ul]
Switch cover
โ—†For electric window lifters, electric seat adjuster and safety switch for electric window lifters. [/ul]
Trim
โ—†Number and position of retaining hooks => Fig.20[/size]21
โ—†Remove trim upward
โ—†Before fitting, fit door handle seals [/ul]
Inside door control
โ—†Undo screw for inside door control [/ul][/ul]
โ—†Press in direction of travel
โ—†Remove from door trim
โ—†Detach Bowden cable Door locking mechanism locator [/ul]
Lock ****
โ—†Not necessary to remove in order to remove trim
โ—†To remove, rotate approx. 1/2 turn (180o) anticlockwise and detach
โ—†To fit, slot into place and rotate approx. 1/2 turn (180o) clockwise
โ—†Installation positionAdjusting clip [/ul]
โ—†Adjusting[/ul][/ul]
โ†’ Fig.1Number and position of retaining hooks, front door
โ†’ Fig.2 Detaching Bowden cable
โ€’Lever off clip -2-.
โ€’Detach Bowden cable. [/ul]
1 -Seal [/ul]
โ†’ Fig.3Lock **** fitting location
โ—†When fitted, the locating cam must point towards the door window.
โ—†Dimension a = 14 mm, button locked. [/ul]
โ†’ Fig.4Front door trim height adjustment
โ€’Adjust height parallel to window slot strip on outside -1-.
โ€’Set trim flush to dash panel.
โ€’Correct height as necessary using adjusting screw -2-. [/ul]
3 -Door subframe [/ul]
โ€’โ†’ Position flat screwdriver in hole on underside of finger plate.
โ€’Push back lugs at both holes -arrow- and lever off cover. [/ul]
Note:
Lever off cover from front towards rear.
โ€’โ†’ Unscrew 3 cross-head screws -2- from finger plate bottom section -1- (2.5 Nm). [/ul]
3 -Finger plate top section [/ul]
Note:
โ—†Old armrests can still be fitted to the new door trims.
โ—†New finger plates cannot be fitted to the old door trims. [/ul]
Removing and installing front door trim impact absorber
โ€’Remove front door trim โ€’โ†’ Open 2 clips -4- using Seeger circlip pliers -6- and lift off.
โ€’Detach impact absorber -2- from door trim -1-.
โ€’Clean adhesive residues from bonding surface on door trim.
โ€’Detach adhesive protection strip and affix impact absorber.
โ€’Slot clips -4- onto locating pin -3- using 10 mm socket wrench. [/ul]
โ€’โ†’ Press on the two retaining lugs of the clip -2- with a screwdriver -1- to bond the impact absorber -3-. [/ul]
[IMG]local://upfiles/12092/7AE1B7D7AAF44AB4B6C0A792B6F78308.jpg[/IMG]
[IMG]local://upfiles/12092/4A179F9674764E78BE7C26F5C372A2D4.jpg[/IMG]
[IMG]local://upfiles/12092/430DAEAE0BC14755A9504EA325E1A5F9.jpg[/IMG]
[IMG]local://upfiles/12092/6DA93A614FD24DB68115E9E7B90D8AB6.jpg[/IMG]
[IMG]local://upfiles/12092/52F2758377034B2B802890F8DBDFEA63.jpg[/IMG]
Old Dec 2, 2007 | 10:21 AM
techbod's Avatar
now you know
[IMG]local://upfiles/12092/05BD398B853D4E84B100AE117A399180.jpg[/IMG]
[IMG]local://upfiles/12092/D6F88189C90849CD882CA4FEB30673D1.jpg[/IMG]
Old Dec 2, 2007 | 10:40 AM
Stargazer's Avatar
Unfortunately, this looks nothing like my car. I will take a pic and send it in a bit.
Old Dec 2, 2007 | 08:27 PM
NH_USA's Avatar
It looks like the door pannel on my 96 and 97 Audi.
timtholen
Feb 24, 2015 11:11 AM
bshusted
Sep 11, 2011 09:57 AM
nismonewf
Nov 27, 2008 08:43 PM
yellow325ix
Feb 26, 2006 11:56 PM
hofackerjk
Jun 16, 2004 01:52 PM
