intermittent oil light ? levels are fine what is wrong?
A Red oil can appears in the info center of my 2003 A6 3.0 Quat. it comes on only at speeds below 70 kms/hr., however it beeps and flashes so obviously I checked the oil as the info station suggests (in dash suggestions with warning)... oil level seems fine however it keeps coming on at low speed. Are there common problems with this description and this model and year etc..??
thanks so much for the help...
Well if there is no pressure its probably the oil pump, or you used a crap bag oil filter without a bypass valve if it cloggs. (Fram, penzoil etc.)
You will be paying 1 hour for diagnosis (whatever the shop rate is)
and how much the part costs and installation. The sensor is around $40 and it only takes about a half hour of labor to install that. So i would say a total of about $200 if its the sensor. If it has a bad oil pump considerably more, however oil pumps hardly ever go bad on these cars. I would just throw on another oil filter just to be safe. MANN, Mahle, Mobil 1, K&N, or WIX filter. How long has it been since you changed the oil? What type of oil do you use?
EDIT: NAPA gold filters are also high quality filters.
Good to hear the oil pumps rarely go...
And as for the oil filter and oil it has been what ever they are throwing in at the dealership... however thus is the reason i'm thinking more and more about doing my own work where ever i am able...
I found a good shop with an ex dealer mech. so he is usually a straight shooter but I wanted to get some opinions first... and you are awsome I really appreciate it..
The dealer uses a MANN or Mahle filter, so that won't be the problem. Basically if you look at the filter it should be black with white lettering on it.
The sensors are pretty common on the 2.8L and 2.7T, but not so much on the 3.0L. So it would be interesting to see what your oil pressure numbers are.
Steve_AudiA43.0L Avant
Apr 3, 2017 11:08 AM
ssingh
Nov 7, 2012 11:30 AM
fyreous
Feb 18, 2010 05:11 PM
rustyleskiv
Apr 2, 2006 08:27 AM
