Just got VAG and this is what it came up with
Old Dec 30, 2007 | 05:22 PM
MiniSpdRcr's Avatar
Default Just got VAG and this is what it came up with
Well I just purchased a laptop with VAG and cables for 15 dollars. Ran diagnostic and came up with this. If anyone could help me figure out what some might be...
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 F Component: A6-Klimavollautomat D61 Coding: 00160
Shop #: WSC 02325 4 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage -
Intermittent 01841 - Potentiometer/Actuator for Temperature Flap: Left (G220)
30-10 - Open or Short to B+ -
Intermittent 00792 - A/C Pressure Switch (F129)
31-10 - Open or Short to Ground -
Intermittent 01582 - Signal for Coolant Temperature
30-10 - Open or Short to B+ - Intermittent
On this one above...could the 30-10 and 31-10 be the Aux fan switch?
Address 35 ------------------------------------------------------- Controller: 4B0 962 258 C Component: Central Lock/Alarm D30 Coding: 15885 Shop #: WSC 02325 6 Faults Found: 01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 00955 - Key 1 09-10 - Adaptation Limit Surpassed - Intermittent 00956 - Key 2 09-10 - Adaptation Limit Surpassed - Intermittent
