k/n drop in or darintake
Old Sep 18, 2010 | 03:32 PM
ratherb1's Avatar
Default k/n drop in or darintake
need some advise for installing a better intake
heres what i was thinking
1) k/n drop in stock box
2) darintake w/o hole
3) darintake w/ holes this option i have a question about... ppl seem to drill the holes on the bottom of the airbox, if so, does this not draw in some hot air from the engine bay
what do you guys think 1, 2, or 3 and the advantages and disadvantage's of the 3
thanks for any help
Old Sep 18, 2010 | 08:03 PM
SILVER A6 2.7T's Avatar
well i have kinda a hybrid i have the darintake holes with a k/n drop-in. sounds awsome. oh and if you look directly under the air box you can see the ground if you loook around. and i also drilled holes in my fender well that match-up with the holes in the air box.
Old Sep 18, 2010 | 11:32 PM
jhuffman's Avatar
Dont go the K&N route. The filters do let more air in but they suck at filtering unless you oil them... which will gum up your maf over time. Go darintake, you don't have to put holes in it though, unless you are running some serious boost.
Old Sep 19, 2010 | 04:12 PM
ratherb1's Avatar
the cone filters need oil to correct? or is cone better at not messing up maf sensor?
i am leaning towards 3in tube w/low profile open top cone filter from advanced auto w/no hole(s)
Old Sep 19, 2010 | 06:28 PM
bob martin's Avatar
I recommend Option 0 - leave it alone. There is no horsepower to be gained. Spend your money elsewhere.
Old Sep 19, 2010 | 06:53 PM
jhuffman's Avatar
I second bob IMHO unless you are running big turbos there is no gain except for sound effect.
Old Sep 20, 2010 | 12:38 AM
ratherb1's Avatar
so everybody that buys k/n drop in, s flo or darintake just wasted there money ? im willing to waste 30 bucks seeing the stock air filter is 20 and the k/n is 50 and the darintake setup cost about the same as the k/n drop in. **** 30 bucks i can probably find that in my loose change drawer lol thanks for your opinion though
Old Sep 20, 2010 | 03:09 PM
hxgaser's Avatar
Yup. Read my sig. I am back to the stock. Unless you are running K04s or something, there is no need to mess with the stock setup. If you want, I will sell you my old K/N which was used for about 3000 miles. Serious.
Old Sep 20, 2010 | 05:29 PM
oldmots's Avatar
I would bag the intake idea, there is nothing usable there for you. You would do way better to install new O2 sensors, plugs and clean the MAF and get the injectors cleaned and matched, replace all filters and fluids using synthetic oils. This will get much of the original power back. Most cars that are this old are down on power around 20% or more, sometimes much more. Getting this back is like a major boost, way more than an air filter will give you.
GDET09
Sep 8, 2008 05:06 PM
So_NAudi
Jul 3, 2008 06:27 PM
betes
May 9, 2008 06:59 AM
pepsicolla
May 8, 2008 09:29 AM
hotgue
Oct 27, 2007 09:02 AM
