Key Fob Synch - One Key Only
Old Nov 17, 2016 | 10:08 AM
mandykemp's Avatar
Originally Posted by RicksAUdi4.2
Do you see a red light blinking on the dash somewhere?
Also..
Steps to reprogram keys to a car they are already linked to:
1. Press and hold the unlock key on a remote
2. Insert key in ignition and turn to on (while still holding unlock)
3. Hold unlock while in the on position for 2 seconds
4. Turn key to off, remove from ignition and release button.
Do this for each remote. Relink to seat positions (press and hold mem position #, then unlock button for 2 seconds and release both) and done.
To program new remotes on a car never linked to previously:
1. Take a key (valet key works best, put it into the ignition and turn the key to the "on" position, so the dashboard lights come on.
2. Roll down the driver's side window (not required, but a good idea in case there's a problem).
3. Exit the car and close the door.
4. With a second key, physically lock the doors by turning the key clockwise (don't use a remote).
5. Take the first remote to be programmed, press the unlock button. The lights will flash once.
6. Wait 10 seconds and press the unlock button. The doors should unlock. That first transmitter is now programmed.
***If you have only one key skip to step 16. Otherwise continue to step 7.***
7. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
8. Press the unlock button two times with a one second interval in between, the lights will flash with each button press for a total of two flashes.
9. Wait 10 seconds and press the unlock button. The doors should unlock. The second transmitter is now programmed.
***If you have three keys proceed to step 10. Otherwise skip to step 16.***
10. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
11. Press the unlock button three times with a one second interval in between, the lights will flash with each button press for a total of three flashes.
12. Wait 10 seconds and press the unlock button. The doors should unlock. The third transmitter is now programmed.
***If you have four keys proceed to step 13. Otherwise skip to step 16.***
13. Lock the door again (physically) with the key, (not the remote) by turning clockwise.
14. Press the unlock button four times with a one second interval in between, the lights will flash with each button press for a total of four flashes.
15. Wait 10 seconds and press the unlock button. The doors should unlock. The fourth transmitter is now programmed.
16. Remove the key from the ignition.
Make sure that to test the newly program remotes, the original key is removed from the ignition since this exits the programming process. Someone might be a bit frustrated trying to test it with it still in 'program' mode.
I had some diffuculty accessing the programming mode. If it doesnt work then take the key out of the ignition and start over. Rinse lather repeat. It will go eventually.
If you are still having problems after trying it more times than you can count, check the key is right one for year of car or that the key and battery are good.
my key broke were its welded?.. so i ordered 2 key fobs from eBay. i had them cut and they will start the car but it turns off after about 40 seconds. i have tried what you suggested and have spent a few hours researching other tips, but nothing has worked.and putting the new key on the original key fob remote won't let the key keep running, but the remote works.. any ideas? not only is the dealership to expensive, but its over an hour away. they said if the keys i bought won't program, i have order a key from them the wait 2 days then go back to get it programmed. any thoughts? also i don't know it this is related but my front windows are half way down and my driver side door lights aren't working proper, and my window buttons aren't working at all. any ideal of help is appreciated
Old Nov 17, 2016 | 10:10 AM
mandykemp's Avatar
Originally Posted by westend
I have a 03 Audi A6 with a strange problem. It will only crank over every 5th turn of the key. Has anyone ever heard of this?
I'm having the same problem
Old Jun 26, 2017 | 10:07 AM
Skot Stover's Avatar
Default One key reprogram
I just put batteries (two C1620) in my fob, and all I did was manually lock and then unlock the driver's side door, then removed the key and tried the fob and it worked. I was expecting to have to do a rain dance and a human sacrifice, but it turned out to be very simple lol.
Old Jul 22, 2017 | 05:47 PM
Tecillo's Avatar
Default Need need key/fob
Just got my first euro car ever. Love it so far but only have one key and get somewhat uneasy thinking the worse lol can any of you guys point me the right direction? 2006 a4 2.0 sline. I'm planning on purchasing replacements from eBay and adding them through this vag-com I hear about. Thanks in advance!
