Key won't remove
Old Oct 24, 2004 | 03:06 PM
MNMAN's Avatar
Default Key won't remove
Hello new to this forum and also a new Audi owner.1999 A6 I have a problem that just started.Sometimes key won't come out after turning car off and parking.This doesn't happen all the time,seems to have a mind of it's own.I have tried the other remote key and same thing.Tried wiggling it,moving shift lever........no avail.Auto tran.Quattro,triptronic.........any ideas? I did a search here and didn't see anyone with same problem.
[IMG]local://upfiles/3080/FABBF576A6214E50AC1028FABA7DA512.jpg[/IMG]
Old Oct 24, 2004 | 07:58 PM
Jestnomen's Avatar
6th Gear
Default RE: Key won't remove
Sounds like it's time to get the engintion cylinder replaced.
Old Oct 24, 2004 | 10:32 PM
MNMAN's Avatar
Seems like it is something electronic that is locking it down...been taking 2 keys with lately because of it,so I can lock the doors and still get back in....but key is in ignition then and alarm won't turn on.
Old Oct 24, 2004 | 11:56 PM
Jestnomen's Avatar
6th Gear
If you have auto, try moving the shifter back and forth out of park and flicking the button. Try moving the steering wheel around all the way, then try to remove the key.
Also, take a look at this thread
Old Dec 14, 2004 | 12:19 AM
wh22366's Avatar
MNMAN I have the same problem occasionally with my 99 A6. What I discovered is that it only happens when I use the Tiptronic to pick my gears and then put it directly in park when I get where I'm going. If I keep it running when I stop and move the shifter in the auto gate back and forth just once, the key will come right out in park. It's gotta have something to do with linkage wear (at least on mine). Incidently, she's got 177K.
Old Dec 14, 2004 | 11:17 PM
MNMAN's Avatar
Never thought of that! Haven't been using triptronic lately and haven't had any probs with key lately.......just other problems
Old Dec 22, 2004 | 10:20 PM
AudiFreak's Avatar
could be the same kind of problem mattlam has in his topic 95 transmission...
Electronic piece that sense the position of your gear... if it doesn't sense that youve selected "Park" the key won't be released...
The problem which wh22366 is having can also be caused by this..
tupp
Oct 3, 2010 09:19 AM
MarcoGaspar
B7 Models
Mar 16, 2009 02:25 PM
VW01AUDI00
Jan 27, 2008 02:26 PM
austina3
Jan 8, 2008 10:05 PM
rccks96
Jan 27, 2007 01:10 PM
