Leaks...two of them
Old Apr 8, 2008 | 01:12 PM
COJAM's Avatar
Default Leaks...two of them
Leak number one....
The filter in the pollen trap is wet and I have water on the passenger side floor. Windsheild has been replaced and Im wondering if it was not put in correctly...Is this common?
Leak number 2. Passenger side. Water got into the Sub and Amp. Caused a deadshort that drained the battery. I pulled the pulg and the battery drain stopped..Is this a common leak? Is there a fix or can I just make a bigger drain hole?
How hard is it to get at that AMP and Sub assembly. They wanted $2300 at the dealer to find the leak and replace the sub...$1300 for the sub and amp alone.
vtraudt
Jul 11, 2008 01:46 PM
kiley8955
Feb 14, 2008 10:43 PM
trevor51590
Jan 14, 2008 01:29 PM
whodatt1
Sep 12, 2007 09:34 AM
speedracer
Feb 2, 2004 03:01 PM
