limp mode problem
Old Sep 5, 2009 | 08:39 PM
jzstuggie's Avatar
Default limp mode problem
Audi a6 1999 quattro seems to have went into limp mode. The prnd234 has tripped and ill have to take it to check for codes tomorow. But The car was just fine. I did take it to get a subwoofer installed in the trunk in which case they tapped into the hi output wires of the stock bose woofer. But car seemed fine. While playing the system battery was accidentally drained and after a jump it seems its stuck in limp mode. And ideas?
Old Sep 6, 2009 | 06:32 PM
jzstuggie's Avatar
Got back the codes. P0705, and P1857, both electric issues with the transmission. Probably nicked a wire under the knee bolster or fried a fuse down there somewhere. Question is...where to look. and what fuses to test.
Old Sep 7, 2009 | 01:27 AM
jzstuggie's Avatar
Also if it help problem happened after the battery died and i jumped it. Any ideas before i take her to the shop on Tuesday?
Old Sep 7, 2009 | 08:26 AM
bob martin's Avatar
I'd start by getting your VAG-COM out and resetting the codes to see if they go away. Could be as simple as the controller got confused when you jumped the battery.
Bob
Old Sep 7, 2009 | 11:41 AM
jzstuggie's Avatar
sounds like a plan. Ill get right on it tuesday and fill in the update.
Staudi911
Jan 15, 2015 03:20 PM
Roderick
Sep 5, 2010 08:11 AM
bottlecap
Nov 27, 2009 05:40 PM
drs305
Dec 10, 2007 11:14 AM
djjay
Apr 20, 2007 02:17 PM
