looking into getting a set of blow off valves
Old Apr 5, 2008 | 10:04 PM
  #31
joetm's Avatar
Default RE: looking into getting a set of blow off valves
i am waiting for the forge hybrid splitters and they can be adjusted from 20/80 50/50 and 80/20 whiich is pretty cool ... im pretty sure that they will be fine for my car??
i think??
Old Apr 6, 2008 | 12:03 PM
  #32
Wayne.L's Avatar
ok........so the ECU will learn to adapt to the BOV on a 1.8t, but will the 2.7t adapt to the BOV??
Old Apr 6, 2008 | 04:01 PM
  #33
halik's Avatar
ORIGINAL: Wayne.L
Sticky in the S4 forum
linky
Old Apr 7, 2008 | 09:39 PM
  #34
cincyTT's Avatar
I'm make believe
ORIGINAL: joetm
i think??
No, they cant. They are either 100% dv or 85% vent 15% recirc only. If you try to go 85% vent and 15% recir you will stall. Reason is the large opening is open at idle. But if you run them like you should, they run flawlessly. ALso make sure it doesnt rattle before install.
Old Apr 7, 2008 | 09:40 PM
  #35
cincyTT's Avatar
I'm make believe
ORIGINAL: halik
ORIGINAL: Wayne.L
linky
That thread is all BS. Yes, the car will run fine with the list i gave above.
Old Apr 7, 2008 | 10:03 PM
  #36
joetm's Avatar
ok so what forge dv can i get that will give me a little more sound?? for the 2.7 t
Old Apr 7, 2008 | 10:11 PM
  #37
cincyTT's Avatar
I'm make believe
007 < splitter < 004 The 004 is a full bov and will work with the car, however it can not be recirculated. This is what i run personally
Old Apr 7, 2008 | 10:30 PM
  #38
joetm's Avatar
well which do you recommend ?? i need to know like asap because ive already placed my order with the guy and told him i wanted the splitters ?? will they work or should i just go with something i cant adjust??
Old Apr 7, 2008 | 10:54 PM
  #39
cincyTT's Avatar
I'm make believe
ORIGINAL: cincyTT
if you run them like you should (15% vent), they run flawlessly.
Old Apr 8, 2008 | 01:00 AM
  #40
turbo kraut's Avatar
Tech Guru
ORIGINAL: trapped
Get a forge DV the 004 or 007 they are good for recirculating air and making a cool woosh noise people are looking for (not me 710n all the way)
i have the 004.... it does not recuirc at all
that woosh you heard... was the bov working
