Maintenance question
Ok so here i go, I am very new to the Audi scene, I just bought a 2004 A6 3.0 30v quattro with 99k on it, the dealer told me they replaced the water pump and the timing belt, and much to my surprise when I did a little digging around under the hood I also found that they had replaced the air filter, serpentine belt and done an oil change, at least i suspect they did as the oil on the dip stick is still caramel colored, so with all of this having been done I was wondering what else I should be looking to get done, should I have the break fluid and transmission fluids changed???? etc.....
Thanks
Sean
Thanks
Sean
Confirm they replaced the antifreeze and serpentine belt -- they should have. Other regular maintenance per my manual:
* every 40k - spark plugs
* every 20k - cabin pollen filter
* every 2 years - brake fluid
My own opinion:
* every 60k - replace front/rear differential fluid
* every 60k - replace manual transmission fluid
* every 60k - fuel filter (the manual does not mention interval); I went 100k on oem
My own opinion:
Replace all the fluids. You don't know what has been done or when. Use good synthetic lubricants. These are very good cars if people take care of the maintenance. I have found over the years that very few people change the fluids like they should. I use AMSOIL in all of my vehicles and at our shop we only used AMSOIL on customers vehicles. Have fun with your new ride. Anthonyz tony@zippyoil.com
