In the manual?
I'm looking in my 2000 A6 2.7T owner's manual and it says you can use petroleum-based or synthetic-based oil. Here's a quote from the book, under Engine Oil Specification and Viscosity:
Your engine was factory filled with an all season high quality engine oil. If you need to add oil between oil changes, use any high quality petroleum- or synthetic-based oil with correct specifications.
The following terms must appear on the oil container singly or in combination with other designations:
-API Service SJ
-ACEA A2 or ACEA A3
-VW 502 00 or VW 500 00 or VW 501 00
As for the interval, the maintenance manual says 8,000 miles.
Hope this helps.
-API Service SJ
-ACEA A2 or ACEA A3
Hope this helps.
MULEPERFORMANCE
Jan 12, 2012 09:35 PM
avinash
Sep 28, 2010 08:22 PM
Gr3gA6
Oct 9, 2007 02:23 PM
