In the manual?
Old Mar 27, 2007 | 02:53 PM
xAUDIx's Avatar
Default In the manual?
Does the 2.7T state in the manual that it requires synthetic oil?
Old Mar 27, 2007 | 03:01 PM
leighsean's Avatar
Default RE: In the manual?
it should, even if it doesnt, you need to run syn.
Old Mar 28, 2007 | 02:04 AM
xAUDIx's Avatar
Bump, i need to know for a claim. can someone look in their manual to see?
Also what the manual says about how often u should change it
Old Mar 29, 2007 | 01:41 AM
jgurland's Avatar
I'm looking in my 2000 A6 2.7T owner's manual and it says you can use petroleum-based or synthetic-based oil. Here's a quote from the book, under Engine Oil Specification and Viscosity:
Your engine was factory filled with an all season high quality engine oil. If you need to add oil between oil changes, use any high quality petroleum- or synthetic-based oil with correct specifications.
The following terms must appear on the oil container singly or in combination with other designations:
-API Service SJ
-ACEA A2 or ACEA A3
-VW 502 00 or VW 500 00 or VW 501 00
As for the interval, the maintenance manual says 8,000 miles.
Hope this helps.
Old Mar 29, 2007 | 05:48 PM
xAUDIx's Avatar
Thanks that exactly what i needed
woutie
Jul 6, 2013 09:27 AM
MULEPERFORMANCE
Jan 12, 2012 09:35 PM
avinash
Sep 28, 2010 08:22 PM
katiebear00
Apr 6, 2010 01:58 PM
