metric?
Old Nov 5, 2007 | 11:13 PM
Polka Salad's Avatar
Default metric?
I was just wondering if there was a way to change the display screen to metric. I like C more than F so thats the only thing i really would like to switch but miles to killometers would be cool too...just wondering thanks
Old Nov 5, 2007 | 11:15 PM
Default RE: metric?
through further searching I found out that you can use vag com so switch your country code and change it but is there another way or do you have to use vag com which i dont know how to use?
Old Nov 5, 2007 | 11:46 PM
auditech79's Avatar
Default RE: metric?
On the factory VAS scan tool (which is basically the same) i use guided functions or guided fault finding and activate module 17 Instrument cluster and use the guided functions for coding the unit.
Search around with the VAG COM you should be able to find test plans for coding the unit.
You can change when the lights come on in the cluster, metric or SAE, all kinds of stuff.
Old Nov 6, 2007 | 01:31 AM
katcoota's Avatar
Default RE: metric?
I second AudiTech. I have only seen it done using a VAG com type device. I still need to get my hands on my friend's one. Just do what I need and give it back
Old Nov 6, 2007 | 12:42 PM
formulagigi's Avatar
Default RE: metric?
no need for all this for the temperature, yu can do it by using your temp-A/C controls. Not sure which for yuor car, but typically you have to press two buttons at once and it is ALWAYS in the manual, did it on my 96 A6 and my current 04 A6. I am a Celsius guy too
I'll check my book tonight...
Don't know abuot the miles to Kilo...
Old Nov 6, 2007 | 02:23 PM
rvt1000's Avatar
Default RE: metric?
ORIGINAL: formulagigi
+1 I think I read it in the manual also.
Old Nov 6, 2007 | 02:26 PM
kouper's Avatar
Default RE: metric?
If you have the mmt/mmi interface there is an option for it under car set up. If all you have is the screen in your speedo there is still a setup place for it. ALmost all cars have an option to switch temperature from F-C hell, my FORD F-350 does, so your audi is guarenteed to.
Old Nov 6, 2007 | 09:41 PM
Default RE: metric?
yeah anything in the manual im going to need help on cause im still without one until i find one and get it ordered
Old Dec 17, 2007 | 01:14 PM
2ltryan's Avatar
Default RE: metric?
With the car running in PARK
1. Press the RECIRC Button
2. Press the Temp Up button
it will flash from F to C or visa versa.
Enjoy!
ckrummy
Mar 1, 2011 01:41 AM
Pjbrof
Nov 11, 2009 08:38 AM
Dallas09
Jan 29, 2009 08:40 PM
greatestates
Jan 20, 2008 04:26 PM
nemohm
Dec 11, 2007 07:34 PM
