Misfire- Coil Pack???
Old Sep 13, 2011 | 05:35 PM
TomKat's Avatar
Default Misfire- Coil Pack???
Hey Guys,
I have a 2003 2.7L with 97k miles
I got the flashing CEL and found cyl 5 misfire.
Pulled the coil pack and the tip and plug were covered in oil .
Pulled the plug and cleaned everything up and expected it to run fine since I assumed the oil was shorting the plug.
It still misfired...
Moved the coil and it misfired in the new location.
OK, sounds like the coil.
Does anyone know if you can check them out with a multimeter.
I checked ohms at the pins they are all open to one another on both good and bad, is there something else to check?
BTW- what would cause the oil in the plug tube?
Thank you
Old Sep 14, 2011 | 08:02 PM
CRuby's Avatar
Oil in the spark plug tube is likely due to leaking valve cover seals.
See #2 Audi A6 Oil Leak - Audi A6 Oil Leaks - Audi A6 Oil Burning Smell
Old Sep 18, 2011 | 03:09 PM
TomKat's Avatar
Default Did the trick !!!
Replacing the coil pack did the trick.
No more misfires, runs great again.
Rock Auto had the Beck/Arnley version for $36
Thanks for the oil leak link CRuby, looks like that my next project
77Audi
Aug 10, 2012 08:08 AM
gabiosz
Nov 15, 2011 05:13 AM
7808
Nov 20, 2010 03:40 PM
kraylon
Jul 29, 2009 12:19 AM
Barust
Mar 4, 2008 07:48 AM
