My 2002 A6 rides rough and has a egg smell
Old Oct 9, 2012 | 10:05 AM
Shawn45's Avatar
Default My 2002 A6 rides rough and has a egg smell
I changed the spark plugs because I thought it was a misfire but the CEL is still on and the car is still riding rough. I'm not sure what the problem is now. I was thinking maybe an O2 sensor swap could fix it. I need suggestions.
Old Oct 9, 2012 | 10:33 AM
sheldon's Avatar
Run a vag com and read the code(s). That will help to isolate the trouble, otherwise you are just replacing parts that might be still good
Old Oct 9, 2012 | 11:07 AM
z28pete's Avatar
Rotten egg smell is a good sign of a bad cat, and the rough running could point to the cat being clogged. Have it tested for trouble codes before throwing parts at the problem.
Old Oct 9, 2012 | 05:53 PM
ManyAudis's Avatar
Rotten egg smell is also an indication of a cylinder not firing. The raw fuel in the cat is causing the smell. If you keep driving it like this you will burn out the cat. Check your plugs, plug wires, ignition coils etc.
As sheldon said, get a VAG-COM and read the codes. It will probably tell you what is wrong.
MyFreeAudi
Nov 2, 2014 04:02 PM
Mark6555
Jul 17, 2014 07:10 AM
ckappler
May 12, 2011 10:06 PM
audiA4gm
Mar 9, 2010 04:42 PM
charnow
May 16, 2009 12:33 PM
