My APR making 17.5 psi of boost?
I got chipped on Thursday and got my gauge today, and the boost is spiking at 17.5. Isn't is supposed to be a 1 BAR/14.5 psi program??
Also, I drove home all the way to listen to see how everything was (primarily to listen for boost leaks from the new TBB and DV's). What I heard was a whistling from the turbos as they spooled, but not under higher boost. Only from 0 to 5, if I recall correctly. As the boost built, the sound went away. If it were a sound of turbo failure, would the sound happen all the way throughout the boost range? is this low-boost sound normal?
It's not loud some some of the "dentist drill" videos I've seen...
Can anyone give me any info about the 17.5 psi of boost from the APR chip and the slight low-boost whistle?
I'll drive it again tomorrow and pay more attention to the details of the sound, speed, RPM and boost related details.
Thanks!
Jeremy
Thanks!
Jeremy
I think your fine ... my giac x chip got me past that level at some points ... I had a manual boost controler so that it wouldnt spike that high ... apr wont work with manual boost controllers though ... so your best bet is to probably order some new piping and enjoy the chip ... you dont have turbo failure they just make more noise now with the new DV and the chip ...
Get some vast piggies and a catback and youll be set!
Hey, I see you finally sold you car Joe! If you don't mind me asking, what was the final parting price? I was trying to sell mine for a little while before I decided to keep it and mod it up...
When you say "new piping", what are you referring to?
I was going to get the DP's done on Thursday, but after I heard the whistling, I was concerned I might need that money for new turbo's!!!
What's the efficiency range of the KO3's?
Thanks
Thanks
Hey nothing77
Just humor me here. This is a little off topic.
If I swap out the stock k03's for the RS4 k04's, can I drive the car to get the re-flash (I am currently running GIAC's program) or will the car have to be flat-bedded to get re-flasehed, in order to be driven properly?
I am thinking that I can drive the car but just wont be able to feel the upgraded power Correct?
Thanks
E
Thanks
E
yea you can drive you will just show no power gains ... also youll prob have a cel ... as long as the cel isnt flashing ur cool
big job man !!!
hey coors you wanna buy my MBC i still have one uninstalled in the bag and itl work with your giac chip!! 30 bucks?!
by new piping i mean the rubber tubing that tends to dry out and crack away ... sometimes when running a chip you can tear the piping but i wouldnt worry about it too much your tbb or a vac line will be the first thing to go if anything
big job man !!!
If your turbos failed, you would notice the complete lack of acceleration right away. You probably can't hear the spinning of the turbos over the louder road noise, exhaust noise, wind noise as you accelerate.
What kind of boost gauge and where/how did you mount it? Any pictures?
I think it was from a company called SDS. I am going to mount it inside the vent on the front corner of the driver's side. it's going to be mar-glassed, recessed down inside the vent. My brother owns a custom car audio shop and he's done it on other customers' A6's before. It looks great and stock, too.
I'll take pics when I get it all done, but I took it out since my car's going to the dealerships and I don't want any problems... (see my other thread...)
Hey coors, You will def be able to drive the car, you may get a CEL and if you try to romp on it you may actually go into limp mode, the problem being that k04's can deliver more charge air, which may put you in a lean condition.
Good looking out!
