My day at the Audi Dealer
Old May 17, 2008 | 08:49 PM
WolfsA62.8Q's Avatar
Default RE: My day at the Audi Dealer
indie , or indy > independent dealer ( Not Audi dealer).
Old May 17, 2008 | 09:04 PM
joetm's Avatar
balance and tru causes shake allignment is pull side to side
Old May 18, 2008 | 01:21 AM
GDET09's Avatar
It doesnt really pulll side to side, it just shakes at higher speeds (50mph+). I hope the dealer wasnt lying to me and just saying its the tie rods. So i hope these are the typical symptoms of the tie rods going bad.
Old May 18, 2008 | 11:30 AM
joetm's Avatar
it is a symptom of a bad end but how many miles do you have on the car because they usually go around 70k ... id stat by replacing them if you are around 70k also if u put your front end in the air you can see if they are bad by grabing a tire and trying to twist it back and fourth like you were turning the steering wheel and it wont move much (obv. bc the u wont be able to turn the wheel much at all bc the car is off and its is hard!) but if there is like an inch of slop or play and there is movement then the tierod is bad n needs to be replaced ...
Old May 19, 2008 | 11:41 PM
GDET09's Avatar
Thanks Joetm. I have just gone over 84,000 miles. I actually lifted it today and this is what it looked like when lifted. [img=http://img179.imageshack.us/img179/4374/badoutertierodjs3.th.jpg] The tire wasnt removed so I dont know if that had anything to do with it. I've read around and it seems pretty easy to replace. There was also little play.
Old May 20, 2008 | 10:53 AM
joetm's Avatar
yea i cant tell anything from that pic lol ... This is what Id do
replace the tierods and then get your wheels balanced if it doesnt go away then your wheel probably isnt tru ... but if you dont see any dents or anything it proably isnt that
Old May 20, 2008 | 12:18 PM
NH_USA's Avatar
If you change the tie rod ends get it aligned !
Old May 25, 2008 | 09:38 PM
  #18
dropscience's Avatar
nice im not the only 17 year old with an a6
i get mine serviced at a german used car dealership but their work is top notch for sure
http://www.autowerkesinc.com/
AWDaholic
Dealerships
Aug 20, 2014 08:51 PM
Msnickbroderick
Oct 13, 2010 06:28 PM
Yanaki
Sep 27, 2007 01:43 PM
the_shogun76
Feb 21, 2007 02:13 PM
Little_chap
Aug 9, 2005 05:54 PM
