my exhaust
Old Jul 18, 2008 | 02:28 PM
reverend's Avatar
Default my exhaust
i started noticing when i get hard on the gas my exhaust sounds almost hollow? almost like an aluminum can kind of howl. could it be an exaust leek somewhere?
Old Jul 18, 2008 | 05:22 PM
joetm's Avatar
Default RE: my exhaust
never driven a 2.8 but all audi exhausts are relatively quiet except for the V8s (which i am envious of)
Old Jul 18, 2008 | 05:29 PM
reverend's Avatar
it just sounds wrong? not sure how to explain it really. then again maybe it is my exhaust manifold? hmmm. who has a 2.8 with stock exaust?
Old Aug 7, 2008 | 04:40 PM
2001A6's Avatar
I did and i remember it vividly, i now have the center resonater and rear mufflers sitting in my garrage though. Could you post a sound clip of it or a video so i could listen to it?
Old Aug 7, 2008 | 04:44 PM
bgrist's Avatar
probably a little leak somewhere. should take it to exhaust shop before it gets worse
Old Aug 7, 2008 | 05:09 PM
oc_audica's Avatar
could be the cats
Old Aug 8, 2008 | 08:27 PM
a6hcw's Avatar
I once made the mistake of putting NAPA exhaust hangers on my 1996 Audi A6 Quattro 2.8L and all three of them broke, causing a grinding noise when accelerating. You could have broken exhaust manifold studs or bolts at high mileage. I used some 5/16" stainless steel bolts, which are almost 8mm for my exhaust. For studs, you can use an 8mm die on one end and a 5/16" die on the other end. You can also order metric stainless steel bolts, however the 5/16" stainless steel bolts are more common at local stores. You may order almost any stainless steel bolt from:
www.mcmaster.com/
Old Aug 8, 2008 | 10:15 PM
wh22366's Avatar
Default Hollow-sounding exhaust
I heard something similar in May and couldn't find a leak. When I rapped on the cats, I found that the guts were loose in one and really loose in the other. Replacing the two cats was one giant pain.
The BHP Project
Mar 3, 2014 07:20 PM
robbib
Apr 4, 2011 05:51 PM
guy4graphics
Mar 31, 2008 10:00 AM
