need a CV joint
Old Jun 14, 2008 | 03:34 AM
katcoota's Avatar
Default RE: need a CV joint
Many many years ago, I was told that it is better to do both sides whenever there is a suspension issue to fix, such as tie-rod ends.
Is the same true forthe CV boots?Should both front sides be changed?
Old Jun 15, 2008 | 01:14 AM
a6hcw's Avatar
If you have cracks in the CV boots, then it is best to replace them before they completely fail. The front outer CV boots are more likely to fail, due to their severe flexing. Perhaps, you didn't notice the small hairline cracks, or you had something hit the boot.
If you have the Bentley Audi shop manual, it will tell you what tools you will need, etc.
You need to inspect the other CV boots for small cracks.
Old Jun 16, 2008 | 07:53 AM
jcollege's Avatar
Ahh lucky me, I was replacing my brake pads this weekend, and also noticed that my passanger side CV boot was torn. Car is still under factory warranty, is this covered? Thanks guys.
Old Jun 16, 2008 | 02:02 PM
s31523's Avatar
I would have to imagine it is. The manual calls for the first CV boot inspection at 60K so I imagine that is about when they expect them to fail. Seems a simple phone call is in order.
Old Jul 2, 2009 | 03:58 AM
D.B.A.'s Avatar
Member
Originally Posted by mrvirgilg
The thing is you have to purchase a 8MM 12 point allen socket to remove the bolts at the transmission (Really Hard tool to find). I had to phone a German tool place in Atlanta to order the part.
go to napa, they have it there for under $10
johnnieb
May 31, 2013 12:50 PM
jinsojoo
Nov 11, 2009 05:59 PM
SuperSquid
Oct 5, 2008 11:39 AM
FOZZIE BEAR
Jan 6, 2008 02:07 PM
boastud
Sep 25, 2006 01:31 AM
