Need exhaust Help!
Old Apr 26, 2009 | 11:29 PM
Retard Riot 686's Avatar
Default Need exhaust Help!
So on my 99 2.8 A6 the flex pipe has rusted out. I got under the car and yeah its pretty bad. My question is i found new flex bellows here http://www.ecstuning.com/stage/edpd/...ory=Universall but how do I got about replacing them? The downpipe, flex, precats all one piece or can i just swap the Flex in there some how?
Old Apr 27, 2009 | 12:24 PM
NH_USA's Avatar
The flex pipes are usually welded inplace by a muffler shop that has the right tools. If the other parts of the pipe are bad you should replace the whole assembly.
Old Apr 27, 2009 | 02:32 PM
wammy18's Avatar
The flex pipe isn't to bad to replace with a straight pipe or replace. You might just need some new clamps and a good tech . You need to watch out because all of the welding is done by the tranny / subframe of the car. This makes it a tricky job because you need to get the top but obviously not weld your exhaust to your car ;P. Or you could also get clamps that connect piping (forgot the name right now of those clamps... will update sorry )... you might need 4 of them but would work. I would go somewhere where they don't rape you for lifting it and taking the exhaust off. I did this with my tech about 2 weeks ago took about 2-3 hours to remove and reweld the piping.
Old Apr 27, 2009 | 07:58 PM
NH_USA's Avatar
Replace the flex with a straight pipe????
Ya gotta be kidding! Right?
They use a flex pipe so that every time the motor moves it dosent move the whole exhaust system and put it in a bind.
Old Apr 27, 2009 | 08:06 PM
mlwartman's Avatar
i'd want to see how much flexing this motor does against the mounts. for decades, exhausts were 1 solid, unflexing piece from the heads to the tips. flex was introduced with front wheel drive. i can't imagine it helps with audible drivetrain noise, but i don't think it would cause a binding scenario.
robbib
Apr 4, 2011 05:51 PM
guy4graphics
Mar 31, 2008 10:00 AM
