Sponsored by:
Sponsored by:
Need help 1998 A6 Q AHA misfire code P0302 problem
Old 08-03-2009, 02:09 PM
Steve2008's Avatar
Question Need help 1998 A6 Q AHA misfire code P0302 problem
Need help to understand this problem with my Audi A6 (1998 AHA engine) was running rough and the check engine ON. The OBD code was P0302 which is misfire #2. The car was running fine no problem, then I took it out to carwash the engine (underhood). I drive it home not problem but the next day I drove it the check engine flashing then stay ON. Please let me know if you can point me the problem so that I can DIY repair. Thanks.
Old 08-04-2009, 09:40 AM
madridlover's Avatar
sounds like something in the engine bay got wet that shouldn't have gotten wet.
did you cover the alternator and the MAF? Did you use high pressure spray??
green2man0
10-22-2014 09:53 AM
A6 Quattro V6 30V
08-06-2010 02:06 AM
Race515facE
02-19-2010 04:20 PM
dhypnotized
03-30-2008 03:40 AM
andrew4g63
09-16-2007 10:39 AM
Quick Reply: Need help 1998 A6 Q AHA misfire code P0302 problem
